B_B_UpchExplorerSep 27, 2017burned plugcan someone tell me what could have caused my plug to burn up? I have an rv with a 50 amp to 30 amp adapter plugged into a 30 amp plus outside. I just noticed the one side of the adapter on the 50 amp...Show More
wa8yxmExplorer IIISep 28, 2017Burned plugs on the 50 amp side is rare, 30 amps burn up all the time.As others have said, bad connections,, the blades on the plug should be bright and shiny, if they are dull or worse yet black they will overheat.Likewise the contacts inside the outlet.
Related Content7 pin plug amperage rating?Chevrolet 6.6 burning oilBurning man?Burning smell from converterBurning RV's
