wa8yxm
Feb 21, 2015Explorer III
Another thing I have found, The Quick connect type outlet assemblies they use in RV's are a bit..er.. anemic when it comes to space heaters..
I smelled hot wire,, Others have had failures of the outlet.
I installed a pair of 15/20 amp outlets (These have a "T" shaped neutral) fed them with 12GA wire bent around a genuine well tightened screw,, Each cable runs to a circuit breaker (one is 15 amps I'll upgrade some day other is 20) with no other loads on that breaker... No more hot wire smell.
38,782 PostsLatest Activity: Sep 10, 2026
