sailor_lou
Jun 20, 2013Explorer
Either one is fine and I'm sure there are exceptions out there, but for the most part the DP will give you a heavier chassis, better ride and is quieter. The heavier chassis will typically be equipped with items like air ride suspension, larger fuel and water tanks, more slides, tile flooring, etc. All this makes the drive more comfortable and makes the RV feel more like home when you're "camped." Also, if you can maintain a gas vehicle, you can maintain a diesel (just larger parts and more fluids). You do need a floor plan that works for you and probably can find that in either type of rig.
Regarding the theory that you need to drive a zillion miles a year to justify the diesel, I don't necessarily agree. We only average about 4k miles/yr and do not see any negatives with the diesel. Good luck with your search.
Lou
05 Travel Supreme Envoy
CAT C7
Lou
CAT C7
