Rick_Jay
Mar 30, 2015Explorer II
Hi,
"Winter Proof" in a tough requirement.
Can you survive a winter in one? Yes, I believe people here have survived northern climate winters in their motorhomes. It generally will require a lot of preparation and energy (propane and/or electricity) to keep it warm. Depending upon where your rig is parked, you may also have to deal with your filling your fresh water & dumping your holding tanks. Will you be in one place all winter long? I think most who winter in their motorhomes use some sort of windbreak/insulation (hay bales, for instance) all around the perimeter of the motorhome. But this makes it difficult to easily move the rig, if needed.
If you can keep the rig inside an enclosed structure which is kept at around 32* F or more, so much the better.
Another thing to consider: How are you at heights? If you have a snow event and then need to travel, you'll have to figure out some way to remove the snow from the roof before you hit the road. A snow covered fiberglas roof can be pretty tricky to walk on. And then you have to make sure you don't break anything on the roof while walking & brushing the snow off.
I'm not saying it can't be done, but I would think you'd be better off renting a space for the winter months and storing the motorhome.
I'm sure others here will have some other ideas.
Good Luck,
~Rick
Good Luck,
~Rick
