Mocoondo
May 21, 2015Explorer II
jonthebru wrote:
I am interested in how easy it may be to modify the simpler CA rigs with more outlets and improved plumbing if necessary. My understanding is they are built as rentals so have some easier operating devices. Is this correct?
I'm curious what type of plumbing modifications you had in mind. You poop in the hole, it drops into the tank...doesn't get much more foolproof then that. :) The plumbing is designed with ease and simplicity in mind. Systems don't get much more robust yet simplistic in my opinion.
As to electrical, wiring is run up in the ceiling through foam insulation. Might be hard to add outlets unless you are ok with exposed wiring, but that holds true with most coaches.
38,778 PostsLatest Activity: Jun 10, 2026
