STEVE-OTR
May 15, 2017Explorer
qcstang wrote:
Hi All, first post in here.
I will be able to retire at the the end of the month without penalty.
So we are looking at buying a CA (CDN version) 2011 Majestic 28A. I have most of the information I need, but can someone please inform me as to what the Carrying capacity of a 28A is? Can't seem to find that info anywhere.
Thanks for any help!
Daniel.
Hi, qcstang:
Open the passenger door, and look right under the inside door handle. There you will see a Yellow label which indicates the Cargo Carrying capacity. I have a 28a and it states something around 3,144 lbs if my memory serves correct. With the door closed, the passenger seat kinda blocks this label and so it cannot be seen easily when the door is closed (see pic). Total that the motor home is designed to carry is 14500 lbs. With the motor home completely empty (empty tanks, only the driver, and empty storage) it should weigh in at about 10,500-11,000 lbs.
If you have all tanks topped off: 9 gals propane, 6 gals water for water heater, 48 gals of city water and 55 gals of fuel, together all of this weighs about 830 lbs which would have to be subtracted from the 3,144. So real CCC is 2314 lbs. If you have 7 passengers and each one weighs an average of 154 lbs then take away another 1078 lbs. Which would finally leave you with 1236 lbs that can be a mixture of food, the dogs or pets, clothing or bikes and any camping equipment.
Sorry I made the reply so long. I hope it helps. Also keep-in-mind that you can have the RV weighed on the CAT scales, Empty or Full, at a Loves, Flying-J or at the Pilot Travel centers.
38,777 PostsLatest Activity: May 24, 2026
