kirbymurphy
Jun 04, 2017Explorer
bghouse wrote:kirbymurphy wrote:bghouse wrote:
So I think all my questions were answered now (or I found in other threads) except for :
3.) Is there room in the CA 23A to add in an inverter and additional batteries / solar?
Any space you want to give up is space for batteries and inverter. In an exterior storage compartment, under a sink, in or under a cabinet, etc. Just remember you'd like to be close to the generator or mains panel to tie in. Is one battery enough or do you need four? It's all a tradeoff
Thank you. Since I need to be able to work, I think the inverter is going to be something I must put in. Need to keep thinking....
Did a bit more poking around and found several posts that mounting inside the cabin is not a good idea due to outgassing. Several mentioned that it has been done successfully when vented properly, but unless one is an expert it's not recommended.
38,777 PostsLatest Activity: May 24, 2026
