bghouse
Jun 04, 2017Explorer
Snowman9000 wrote:
Bghouse, I have the exact same items on top of my Sunseeker 2300. I installed 2x 100 watt and 2x 50 watt panels, each far enough away from objects so as not be shaded at a 45 degree angle. I could have put quite a bit more up front where the antenna could shade them if it was cranked up. 300 watts does an EXCELLENT job for my two batteries.
If you search posts older than one year, Tech Forum, my username, keyword solar, you should find a post showing the sketch I drew of my roof. It shows how to plan the locations where you can put solar without too much shading. I am confident the 23A would have enough usable space.
Hi Snowman9000 - is the Sunseeker 2300 the same as the Cruise America Thor Majestic 23A? The Thor Majestic seems to be the only model at CA at this time.
I'll definitely go read up more on the solar, but I'm concerned on the single battery and lack of inverter. I will probably start at campgrounds, so don't want to be running a generator and annoying neighbors to be able to get onto my laptop and work. Then I'll eventually try some boondocking also - but even the simple "I need to park overnight at this Casino" still has me needing to get online with my laptop.
38,777 PostsLatest Activity: May 24, 2026
