IAMICHABOD
Jun 14, 2017Explorer III
510dogmom wrote:
Hello again, I have a question and a brag.
First of all, folks with CA 23A models with dualy wheels in the back, do any of you use tire valve extensions? If so, which ones? Do I need to replace the original valve stems?
What is needed is a extended valve stem that will let you quickly check your tire pressure. Braided Extenders have a very bad habit of leaking.Just replace yours with the extended ones.
The best on the market,that are the original,are Tire Man.
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help.
The kit looks like This it is for all 6 wheels,they also come with flow-thru valve caps so you don't even need to take them off to check the pressure.
Here is a list of all the products he sells.
They are compatible with all Tire monitor systems.
38,777 PostsLatest Activity: May 24, 2026
