Mocoondo
Jul 31, 2017Explorer II
socal77 wrote:
Photo of RV leaning
See the photo above
Hi Guys, I mentioned this issue a couple months ago but have put off handling it until now. My 2009 28A from CA has developed a serious lean to the driver's side. I've eliminated the more obvious potential causes - I emptied all the tanks to make sure it's not some type of extra weight on that side.
Took it in to get the tires rotated and the guys who did it said it definitely was a leaf spring issue. I've looked under there myself but nothing obvious from my untrained eye. So now I need to get it fixed. The RV shop where we live here in Redlands, CA is crazy expensive so that's not an option. I know someone previously in this forum mentioned a place down in Orange County that specializes in RV springs and is reasonable priced. The RV has 164,000 miles on it so I think the springs have just gotten tired. I'm open to all suggestions. Thanks!
Take the vehicle out on a quiet road, get it up to speed and turn it hard to the left, not enough to tip it over, obviously, but enough to make it lean to the right. Nine times out of 10, that will cure your lean. If not, then you are in new spring territory, but I would be surprised if you needed new springs.
38,777 PostsLatest Activity: May 24, 2026
