craz_z
Jan 31, 2018Explorer
60-65 in the front is about right after that the front end does feel abit icy not enough weight on the front to justify going up over that the rear is a different story.
Rears are around 70-75 up to 80 depending on load.
Load E tires go to 80psi max. which is what all of the 23a's should be. IF you don't have the borg tire valves I highly recommend buying them on the next tire change.
38,777 PostsLatest Activity: May 24, 2026
