cencerrita
Aug 05, 2018Explorer II
Tequila wrote:sachilles wrote:
Two weeks in. My only real "issue", is a minor one, the green light indicates that the battery is solar charging does not seem to work. I took out the tamper proof allen screws from the panel, and replaced with standard philips head screws. I found the panel is producing power and gets to the led, but the led doesn't illuminate. Almost looks like someone tried to re-solder the led to the mini circuit board it's on. I don't need the light, but wonder if they sell a replacement board and LED. I swear I read somebody has had the problem recently.
I have not seen the lED light up on mine either. I havent been up there, but i am guessing its a small panel on the A?C which is probably only good for trickle charging. I plan to put at least 100 Watts up there.
I took the information off the panel a couple of years ago but the manufacture never answered me. Failure of the unit seems to be a common problem. Ended up fitting a new small unit above the panel to control the roof solar panel and wired into the existing sytem having completly removed the exisiting neon unit with charge contol.
38,777 PostsLatest Activity: May 24, 2026
