texasvwnut
Jun 05, 2020Explorer
cencerrita wrote:texasvwnut wrote:
General question about solar on these ex-CA rentals. I read some of the earlier posts on solar. On the Coach I'm in the process of purchasing, I'm being told that the solar cell is in place but the charging light will not indicate something is working on the panel. Assuming the worst, is the cell on these a generic unit I can be procured easily? My first angle will be to get CA to fix whatever the issue is prior to delivery.
Our cell always worked but the control panel unit was not working and the company that made the bits never replied to me. I know when we brought our 27G it seemed a waste of time following up as the panel was so low a wattage. I fitted 200w solar panels anyway that were moveable around the RV to the sunshine and that was more than enough for boondocking.
Suggest the easiest way forward for you is to fit a new bigger panel on the roof using existing cabling and then open up the tank control panel were the existing controller is (or was) and wire to just outside a new solar controller. Again using existing cables that go down to your battery. There was lots of sare cable length inside ours.
Thanks for the information. What type of 200w panel(s) did you go with? Did you mount them on the roof with the ability to tilt?
38,777 PostsLatest Activity: May 24, 2026
