Germax
Aug 07, 2020Explorer
It looks that I will have to use axle.
Manual suggests that and frame goes up and over in that area.
It is high and even if jacked against the frame I think the wheels would sag on the springs.
I got 8 Ton jack https://www.princessauto.com/en/detail/8-ton-hydraulic-welded-bottle-jack/A-p8760886e
9 inch minimum height, I hope those tires do not go three inched down. Maybe I need shorter jack?
fadumpt wrote:
Be careful pulling the sticker, on mine it was going to take both of them off. There was a barcode sticker on the underneath though, so you might have that.
For the jack, there should be flat frame railing going from front to back. You should not have to use the axle.
38,782 PostsLatest Activity: Aug 30, 2026
