MtnBikeMarty
Oct 21, 2020Explorer II
fadumpt wrote:
Do you have any ideas which upgrades to steering and suspension made the most difference? We already had the steering bits that were bad replaced and an alignment (desperately needed) and added the roadmaster steering shock (I'm thinking I have to adjust it though) The rear antisway seems very thick already but it looks like the front could use replacement. I'd personally love to lower the toilet in the 28a (and of course a 50 gallon grey tank)
I did my upgrades in piece meal...The new steering stablizer, seemed to eliminate/drastically reduce steering wheel dancing, the constant movement left to right to left...just to go straight down the road. It definitely brings the steering back to straight quicker when completing a turn.
My original front anti-sway bar moved about 6" left to right when you just grabbed it and tried to move it. The new one, does NOT move one millimeter. It seems to have eliminated/reduced blow by from semi trucks passing, and having to white knuckle the steering wheel.
The rear anti-sway bar definitely reduced/eliminated the coach from rocking and rolling when I pull into my driveway with it's rounded curb, and anything on the counter or table would go flying before.
The pre-story to all this is I had my 27G almost 4 years and we had a front left shock blow out on the highway, we think metal shard's damaged the two left rear tires. Towed into a shop (thank the good sam roadside assistance policy), replaced all 4 shocks (should have upgraded to bilsteins, but they had already installed Ford OEM's before I thought of upgrading and called them), and went ahead and replaced all 6 tires (two damaged and all were beyond 5 year old mfg dates), plus AZ is tough on tires with the heat. I did have them put the "youngest" good tire on as the spare.
While the rig was in the shop getting this done, I started looking on line about upgrades I could to make the drive/ride better. I did add front sumo springs, not sure how much impact they have, maybe when I have the rig heavily loaded??? I do want add rear sumo springs when I start towing a car with my rig. You can scroll back this thread and see pics and story adding those upgrades.
As for the tall shower step, my 27G is the same, the 27G is no longer offered but it's very similar to the 28A, just about 3 ft shorter but still the E450 v10 chasis. I think it's just the grey tank under it (at least for the 27G), which lowering it would reduce your grey tank volume. We use a small folding step to get in and out of ours and I added some grip tape to the step. But I'm not replacing all that and I plan to install a shower grab bar when I get a chance.
Happy trails...
MtnBikeMarty
38,782 PostsLatest Activity: Aug 30, 2026
