cencerrita
Dec 02, 2020Explorer II
quasimatter wrote:eldel wrote:quasimatter wrote:
Anyone know where is the fresh water drain plug on Majestic 28A?
Under the bed. Lift the mattress, unscrew the wooden top and the fresh water and drain are right there.
Thanks - I suspect the fresh water tank is there (but then I wonder where is the fuel tank? Fuel inlet is right below bedroom window).
BTW - I found fresh water drains right next to gray/black water drains. One is for cold water and other is for heater. The quarter turn stop valves are there but the pipes further to center of RV and water drains from there.
If the fresh water drains you have found are small diameter then it is only for the pipework and not the tank. Also when built a standard length with presssure end fittings seems to get used for the water pipes after the pump and consequently they will not drain down fully due to uphill sections:( I always used a air compressor to clear the lines via the shrader valve connection. Amazing the amount of water you get out. Water drain down and winterize
