quasimatter
Dec 02, 2020Explorer
cencerrita wrote:
If the fresh water drains you have found are small diameter then it is only for the pipework and not the tank. Also when built a standard length with presssure end fittings seems to get used for the water pipes after the pump and consequently they will not drain down fully due to uphill sections:( I always used a air compressor to clear the lines via the shrader valve connection. Amazing the amount of water you get out. Water drain down and winterize
WOW - thanks a lot for the link and the write up with pictures. I also went through your entire travel-blog; such fascinating stories/trips. THANKS.
