pnichols
Dec 24, 2020Explorer II
Majestic31 wrote:
I purchased a four winds Majestic 2011 28a last year, 120.000 miles on it I had to replace all of the tires, all new Bilstein shocks.rear camera,TV mount, 3 Vent covers, Roadmaster Reflex Steering Stabilizer Best addition so far, Sumo Springs bump stops Rear HEAVY DUTY, Front regular, Wheel alignment Looking to buy Sumo springs heavy duty rear fake air bag to try to stop the heavy bang in rear going over bumps, water empty rv unloaded still bangs going over bumps Sumo bump stops helped 50%,New passenger side mirror,Water filter system, Screen door bar, All new valve stems,
Wow ... why did you need to do all of that on a 2011??
By the way, I stopped the banging in the rear of our small (24ft) Class C on it's overkill E450 Ford chassis by having installed in just the rear two of Koni's (expensive) Frequency Selective Damping shocks. We have a much, much better ride due to the FSD shocks' light damping on potholes and road surface cracks. (These shocks switch to stiff heavy damping in other situations.)
The ride in the front has always been good with the E450 coil springs. Our chassis has always sat level regardless of how we load it. The front suspension shocks and steering shock are still original OEM after around 86K miles on the chassis. The E450 chassis also came stock with both front and rear anti-sway bars.
Since I first started looking for a Class C before we bought ours new in 2006, I wanted a chassis rated for a much higher loading than what the coach of a small Class C would require, and it has paid off. Unfortunately the combination of a chassis rated for considerably more weight than what is actually needed for a Class C coach is becoming very difficult to find nowadays. However, I think that for sure both Coach House and Lazy Daze still offer 22-24 ft. Class C motorhomes based on the Ford E450 cutaway chassis with the new V8 engine. This approach kindof goes along with ... "if you want a tool to be reliable and last a long time, buy a heavy duty one but use it in a light duty way".
