Sullyd61
Jan 22, 2021Explorer
eldel wrote:thank s for the info.Sullyd61 wrote:
Hi
I ordered a 28a2017 through the Manassas va. Location . Anyone have any information about getting an inspection in that area . They say they are refurbished in Mesa Az. And then driven to va. Via .hired driver or 1 way rental. Has anyone purchased extended warranty and attempted to use it . Should I expect or ask for anew set of tires . Should batteries be new ? Do they do a complete trans mission fluid change with a new screen.
I skipped the warranty when I looked at the small print. The 30 day one is quite comprehensive though so make sure you take a trip in that time.
They don't change fluids - or test them. I had a complete fluid test and was told "well you can change it if you want". I did.
The battery will be original as long as it holds some charge. The tires will be as is unless illegal.
I did use an outside inspector (in Denver so not a lot of good for you I'm afraid) and I'm glad I did. When they refurbished the roof they didn't finish it correctly.
