TwistedGray
Jan 25, 2021Explorer
Floridastorm wrote:Sullyd61 wrote:eldel wrote:Sullyd61 wrote:
Hi
I ordered a 28a2017 through the Manassas va. Location . Anyone have any information about getting an inspection in that area . They say they are refurbished in Mesa Az. And then driven to va. Via .hired driver or 1 way rental. Has anyone purchased extended warranty and attempted to use it . Should I expect or ask for anew set of tires . Should batteries be new ? Do they do a complete trans mission fluid change with a new screen.
I skipped the warranty when I looked at the small print. The 30 day one is quite comprehensive though so make sure you take a trip in that time.
They don't change fluids - or test them. I had a complete fluid test and was told "well you can change it if you want". I did.
The battery will be original as long as it holds some charge. The tires will be as is unless illegal.
I did use an outside inspector (in Denver so not a lot of good for you I'm afraid) and I'm glad I did. When they refurbished the roof they didn't finish it correctly.
Thanks for the information
According to the Cruise America brochure and the Orlando Sales Manager they provide a 3 month/3,000 mile Power Train Warranty. We will plan on using the motor home quite a bit within that 3 months in order to shake out any imperfections. By the way, does CA give you any of the supporting equipment such as Water Pressure Regulator, 30 AMP Surge Protector, Water Hose and Sewage Line, etc.?
Water house and sewage line - yes
Everything else - not to my knowledge
