CwglIndn
Jan 31, 2021Explorer II
Update after owning our CA 2015 23a since last March.
Backstory: bought fully refurbished from Las Vegas, drove home and immediately had a generator circuit board fire which was repaired by CA, along with a waterline leak and smoke detector. Also got the power train warranty and an awning.
We have done a long 3 week 3000 mile trip, and many short trips. Only big mods were side steps, mud flaps, VanTop rear camera, tire pressure monitors, trailer brake controller and a 7 pin trailer connector. Little things include TV mount, wood sink cover, stove cover, brace bars in cabinets and a large bar across the top cab to hold supplies steady.
Driving: Been great, we struggle steep 7% or higher grades and will get smoke if I push it too hard. Our tow says 5k capacity, but towing a 2500lb horse trailer empty really slows on those steep hills. I plan to get the engine pressure checked to make sure everything is good while I have the warranty.
Inside: We have had some insulation disappear on the bottom of the door, which really increased noise, luckily I had some weather strip left. A clasp on the drawers broke and we had to replace. A rear mud flap and its support got pulled into the tire, probably in strong wind, still have to replace. Had to do minor caulking in bathroom and exterior mainly for prevention, especially around the front clearance lights. While driving in high winds the stove vent flap got pulled out of it's plastic socket, as i didn't have time to check on the highway I duck taped it shut. Later, after pealing the duct tape off, I was able to pop the vent back into the socket. I want to add a vent tab (like non-automatic vents) to switch the vent on and off (then I'll have to remember to slide it open).
Everything is pretty routine, and the only significant issue is our refrigerator no longer works on electric. I think I know the issue (possible heating element or loose connection) but gas works fine.
Recently did our 1st 5k oil change. Only regret is we wish it was a E450 instead of E350 because towing is really important to us. Might add better stabilizer bars, primarily to rear later. Also might try to steal horsepower with better exhaust or intake, but not anytime soon. Level towing or light hills are fine with about 4300lb horse and loaded trailer.
Good luck all!
Good luck all!
