Booner
Mar 10, 2021Explorer
Jecraig4734 wrote:
They ran along the top of the fresh water tank. They ended being the wires for the cargo lights in the basement. I couldn't use them be a use the ran from the switch to the other light, so they would only work work if the switch was on.
OK then.
Read my post to you at the bottom of page 148 which will tell you how to wire something using the interior lighting circuit.
I'm assuming you have a light fixture under the cabinets that are over your bed. This 12V circuit is always hot and all you have to do is splice into it before the light switch. The wire that goes to the switch will be the hot wire.
-or-
Wait a day or two and I'll take some pictures of how I wired in a USB outlet by my bed using the light circuit. I want to charge my phone at night while I listen to podcasts.
You never responded to my question as to what you need the new outlet for. Something like a USB plug, or perhaps a radio isn't that much of a extra-load for the circuit. If you want to plug in an electric blanket or coffee pot-that may be too much and they should have their own circuit.
