MtnBikeMarty
Jan 20, 2022Explorer II
Howdy all Former Rental Owners!
I finally installed my Christmas present... Running boards, great addition as I get older. DeeZee 39" diamond plate running boards, about $230 from Amazon. Not too hard to install, cause I was able to do it, but kinda hard too, you gotta drill 2 holes in the frame for the brackets on each side, as well as, drilling in the pinch welds under the door and in the wheel well. I broke 2 of the DeeZee sheetmetal screws as I was ratchetting them into the frame, gave up trying to drill them out, figured out I could use 2 existing holes (passenger side) and bought bolts/nuts/washers and used them instead.
Drilled driver's side carefully, WATCH OUT FOR THE BRAKE LINE AND GAS LINE, and then I used the purchased nuts and bolts, instead of the mfg's large sheet metal screws again. Measured and marked several times before drilling, lined everything before tightening them up with blue lock-tight, that I decided to add as precaution.
Life is so much nicer getting in and out of the cab, and I have mud flaps now, cause you know how stuff sprays up on the front edge of the coach.
