SJ-Chris
May 16, 2022Explorer II
SJ-Chris wrote:
2015 Thor Majestic 28a - Black waste tank removal and repair...
I just completed a fix on my Majestic 28a. Learned a lot and thought I would post the link here also in case any fellow CA Majestic owners would find it useful or be searching for it...
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/30326133.cfm
If you scroll down to the ~10th post there is a complete description with photos/etc
Happy Camping!
Chris
IMPORTANT PREVENTATIVE NOTE: My RV only had 2 brackets in the front edge of the black waste tank holding it up to the underside of the RV. Each of those brackets had places for THREE screws, but they only had TWO screws in each. So, essentially it was being held up by 4 screws. I have since added a 3rd screw to each of those brackets AND added a 3rd bracket on the front edge. You should take a look at what you have on yours and you might want to add some extra screws and perhaps another bracket BEFORE you have this problem and then you can avoid it in the first place! I have another identical Majestic 28a and it also only had 2 brackets with 2 screws on each so I also added more screws and another bracket to that RV as well. I also added 2 additional screws on the rear 2 brackets (there wasn't room for a 3rd bracket).
Good luck!
Chris
