SJ-Chris
Oct 19, 2023Explorer II
Have any of you noticed on your Majestics from Cruise America that the external running lights and the tail lights don't have any rubber gaskets/seals?
I have two 2015 Majestic 28a Class C RVs. I have had to replace a couple of the running lights and just recently I had to replace the tail lights. In each instance I noticed (and was a bit surprised) that there is no rubber gasket/seal between the plastic item (running light, or tail light) and the side of the RV. The plastic running light housing is screwed into the RV siding and that's it. Seems like water will certainly get in over time.
Just yesterday I replaced the tail lights because some of the moulding around one of the tail lights deteriorated. Here are some photos of the existing tail light without any gasket, and the new ones I installed. You can also see the wood has some rot, obviously because there is/was no gasket/seal.
It has been on my to-do list to add gaskets behind all my running lights (and now tail lights), but I've been a bit lazy because I'm not looking forward to the task...You might want to look at yours as over time the wood underneath will rot.
For my running lights, I bought this to make gaskets/seals...was inexpensive. Now, just need to get motivated :)
https://www.amazon.com/gp/product/B08B3ZS1CS
Anyone else observe this on Majestics and/or other RVs?
-Chris
-Chris
