camperdave
Feb 19, 2019Explorer
2010camaro wrote:
It is a 2009 Four Wind Dutchman 28'
We bought it today. Not sure where to find the towing information and the hitch doesn't seem to have specs.
Where might I find the info?
One way to figure it is to check the door jam for the truck specs. There should be a GVWR and axle weight limits on the sticker.
Best would be to actually weigh the motorhome as it sits, then you'll have an accurate rear axle weight and will know how much you can add to the hitch and stay under the limit.
There should also be a large sticker somewhere inside the motorhome (mine is in a rear closet) that lists the Cargo Carrying Capacity. This sticker should show the unloaded vehicle weight as it left the assembly line, as well as GVWR and GCWR. Mine lists the hitch rating and tongue weight limit too (5000/500), not sure if they all do.
See if you can find that sticker inside the motorhome, it may hold your answers.
