DaHose
Oct 24, 2013Explorer
If you want to comfortably sleep up to 8 people, then you would need to buy an RV with something along the lines of dual slideouts with dual couches that convert to beds. Otherwise, you will be stacking like Bordercollie says. A class A will be down on sleeping space, so I think a class C is indeed what you will end up with.
If you are buying used, water damage is a HUUUUUUUGE concern. That is your number one enemy. You need to learn how to inspect for it. Water leakage in the cabover is the most typical issue, but it can happen all over. Bubbling in the siding is a tell-tale sign of leakage. In modern RV's with the very flat and smooth sides, the whole side panel is one bonded piece. If there is bubbling/separation on the outer skin, that is deal killer. Warpage compromises the structural rigidity and is prohibitively expensive to fix.
It's different everywhere but in my area, I found that class C's less than 10 years old in good condition were upwards of $30K. RV's in the 10-15 year old range were in the $25K range. Slideouts make for higher prices and more potential water leaks. Buyer beware is triple true with motorhomes. If you can find someone local who has owned older used motorhomes, they will be a great resource for you. I have found that other RV'ers are always happy to help and will gladly share their experience.
Jose
Jose
38,706 PostsLatest Activity: Jan 20, 2025
