rgatijnet1
Mar 08, 2015Explorer III
Those things are inexpensive. If you do a little searching, you can probably find sealed LED replacements for a couple of dollars more than just the lens. If you go for replacements, be sure to get the two wire type since most coaches do not use the body as the ground.
38,782 PostsLatest Activity: Sep 02, 2026
