- partsman01ExplorerWell I winterize every year, up here it can get cold, and I use three of these items that are supposed to help keep moisture away.
- memtbExplorer
mtofell1 wrote:
4-season trailer is kind of a joke. - Really, it's just marketing hype. I'll run an oil filled radiant heater to keep from winterizing for short periods and/or if the temps are too cold. Otherwise, I just drain out the water, blow out the lines and pour anti-freeze in the tanks.
I respectfully disagree! Yes... per cublc foot of heated area, it will require more heating than a well insulated stick and mortar home. And, I will not hesitate to use my camper at a -20 F and below.... and have done so!
It's simply a matter of construction.... you can't run a Ford Pinto in the Indy 500 for numerous reasons! :R - mtofell1Explorer4-season trailer is kind of a joke. - Really, it's just marketing hype. I'll run an oil filled radiant heater to keep from winterizing for short periods and/or if the temps are too cold. Otherwise, I just drain out the water, blow out the lines and pour anti-freeze in the tanks.
- colliehaulerExplorer III
DE47 wrote:
Intelligent thing to do.
Thanks everyone! I winterize my other trailer but the people I bought this from said they just left the heater on low all winter..... I'll winterize this one as well... - JerryandSusieExplorerNot sure your insurance company would approve.
- DE47ExplorerThanks everyone! I winterize my other trailer but the people I bought this from said they just left the heater on low all winter..... I'll winterize this one as well...
- rhagfoExplorer III
DE47 wrote:
I have a 4-seasons 5th wheel that I recently put a cover on for the summer. If I leave that cover on can I still run the furnace over the winter to keep the underbelly warm?
What is your goal? Do you want to avoid winterizing the water system, or keep out the damp?
I assume you have power to the unit while in storage, otherwise you Gould kill the battery in short order.
If you have at least a 30 amp outlet available I would suggest installing a Cheap Heat system, and run it as it is all electric, dry heat and no heat out the exterior vents! Ice heated air through the heating ducts. - DavidPExplorerI say heat it to keep all your seasonal guests cozy for the winter. :D
- sch911ExplorerYou'll need to be prepared to change out the L.P. tanks way more often than you may think. Heating an RV with the furnace all Winter is going to be very expensive...
- lee_worsdellExplorerseems to be pretty expensive to run your furnace all winter. I would winterize it don't take that long
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
