aztecaa
Dec 09, 2013Explorer
Matt_Colie wrote:
azteca,
Your coach is old enough that it could just be a type of converter referred to as a Buzz-Box. These were regulated by being tuned to the 60Hz line frequency. They provide a very stable output voltage. There is one problem, most were set up to provide 14.4VDC. That is real good for the lights and stuff, but it will destroy batteries in relatively short order if you leave it on.
Why don't you read the tag on it and come back. In the mean time, leave it online only long enough to get a good charge on the house.
Matt
You are correct about the battery life. Since I have solar connected to the battery banks with a charge controller, How can I stop the Shore Power from Charging the battery banks?
Is there a fuse in the RV I can pull that will stop the Shore Power from Charging the batteries?
