tinkerer's avatar
tinkerer
C7 oil pan rust
I have noticed the oil pan on my 2007 coach's C7 Cat has a lot of surface rust on the oil pan with most of the paint peeling off. This is the shallow oil or 19 quart oil pan. I was just wondering if anyone has had the same problem and what they did about it. Maybe I shouldn't worry about it but it does bother me as I don't need a leaky oil pan.:h
  • My oil pan got to the point that it had to be replaced - oil was actually oozing out of it. The price for a new Cat pan with gasket in the US is about $400 in Canada it's almost $800, tack on 2 hours labor and it's north of $1000 to fix. You would think that Cat would have figured out a way to keep this part from rusting. My toad is basically the same age and the oil pan is as good as the day it was installed.
  • Caterpillar sells their paint in spray cans.
    Sand to good metal (use ospho or other to remove rust if salt has really done a number on the metal).
    Paint with the same paint used at the factory.
