jeremywatco's avatar
jeremywatco
Cabinet Repair
Whooops. Thought it was a great idea to remove the panel above the refer to take a look as I was trying to shortcut running some wiring for something.. Well bad/bad news. No wires back there and now I dont know how to put this panel back on.
There is no access to this area from the back/sides/bottom... not sure how the heck to put this panel back on.
Do they sell suction cup clamps or anything? That I could suction onto it and pull maybe put a bead of glue on it or something... I'm at a loss.
Thansk!
  • Rollnhome wrote:
    Velcro
    Good idea, wish I have thought of that.
  • as stated Velcro, also you can use Hot glue sticks along with glue. The hot glue will hold till the glue sets up.
  • Glue two small pieces of metal to the back, then use some 30# magnets from HD on the front to pull it. The only problem is holding it long enough for the glue to dry, need to find something fast. May not even need to glue the metal to the back if the magnets are strong enough. They make them up to 90#. But then you'd have the metal maybe rattling around up there.
    Bill
