Jim@HiTek wrote:
Ahh, if only it were true. But it's not.
I was in a RV park just yesterday, a big one in a metropolitan area, where I had to put a deposit on a Comcast cable box with remote. Than hook it to the parks cable connection and to my 'Smart' TV.
As you drive around the country, like I do, you'll find all sorts of setups. The easiest just require you to connect to the parks cable connector at the power tower and the set the switches on your routing box, than set the TV to scan cable. Others require a separate box they get from the cable company for their area. Sometimes you have to rent that box, other times, just put a deposit down on it. Some of these boxes are proprietary digital, others are old fashioned analog and your TV finds the signal on analog channel 3 or 4.
It's a mishmash.
I don't doubt your story, but in 15 years of RVing, I have never found an RV park that required a cable box. So I don't know how common that situation is.
