somuch2see wrote:
Had to purchase a tailgater as old system is too old and doesn't work with new tech. We want to unit down on the ground by the M/H as I'm to darn old to be climbing up on the roof. Anyway, we ran the coaxial cable from old unit(on the roof) lays flat for about 2 1/2' then through the ant an then another 2 1/2' and then down the side of awning leg which I attached it to. Want to attach the cable to the roof somehow(as I think it will vibrate and make all kinds of noise up there)but I don't want to drill any holes or duck tape it as the tape leaves such a mess. Have purchased some lexel silicone to run over the top of the cable but that stuff is there to stay and impossible to remove if you ever want to. Any idea's would be greatly appreciated as I'm at my wits end..Thanks
If you just want to attach it, I would use some lock tight adhesive (the liquid nails style). Would be simple enough to just mush it into the adhesive and leave it there for a couple days before driving.
