pnichols
Nov 10, 2013Explorer II
I'm not sure I buy into the idea that the Class C cabover design is inherently leak-prone.
After all, take a look at one of the most popular RV designs of all time - the fifth wheel. Isn't the front-end of a 5'er a "protruding cantilever" design just like the cabover of a Class C is? It sure is. In addition, the cantilevered front portion of a 5'er has to carry way more leveraged weight than what the overhead cab cantilevered portion of a Class C has to carry - even including the extra weight of stuff one may have piled on top of the Class C bed when going down the road.
Also, the cabover section of a Class C is above the smoothest riding part of a Class C - the front end where the gently bouncing coil springs are. There's no harsh vertical pounding in the front of a Class C like there is at the back where the leaf springs are.
If seam leaks in the front of fifth wheels is "not a problem" (I'm not sure 5'er front-end leaks aren't a problem - I don't hang around the fifth wheel forum!), then there is no inherent design-limitation reasons why the cabovers of Class C rigs should be, or at least need to be, a problem. That is, unless Class C motorhomes are just plain getting put together more shoddily than 5'ers are ... which I doubt.
Our 2005 cabover area has been wet some, but not due to seam leaks. The cabover window was shattered by a rock from an on-coming gravel truck and we had to travel all the way across the U.S. with an improperly installed replacement window before we could get another one installed properly back home. Front cabover windows should not be there and I'll never buy another Class C with a cabover window in it.
Also, don't discount how much leakage damage can result from leaky cabover clearance lights. If these lights leak, the water goes right down in between the walls and might not show up until a long time later after a lot of rot and/or mold and mildew has taken place.
Just as a reference point: We RV with friends who have a 1994 Class C and it's cabover has never leaked anywhere ... so it can be done.
