super_camper
Feb 11, 2014Explorer
Mocoondo wrote:pnichols wrote:
I'm well aware of all of what you say above ... within the conditions of when and where the various engineering principles apply. (Masters + in engineering fields, too ... FWIW.)
As much stiffness in Class C non-one-piece-walls/roofs design cabover areas is the name of the game if you're going to keep their interface points ("seams") from flexing relative to each other. You don't want seams flexing between themselves if you're going to keep sealants in them from being under unnecessary physical stress. You also don't want UV rays drying out and/or breaking down the chemistry of those sealants.
Cabover Class C areas do not have to "automatically" leak anymore than vehicle roofs leak - over the years. One has to know some very basic things to look for when buying a Class C as to what might keep any one particular Class C cabover setup from being future-leak prone. It doesn't take advanced, or any, educational degrees to figure out what might be required.
Ron Dittmer has posted plenty in these forums on some excellent basics to look for in RV roofs in general, and cabover roofs in particular, regarding what designs might or might not leak in the future with an RV.
My posts here in this discussion thread were merely to add some comments on sensible internal construction details that us buyers and OEM manufacturers should be keeping in mind if we want to buy, or they want to built in, a quality product strength-wise so as to help with seam-leak prevention. OEMs don't even need extensive engineering staffs to apply good old backyard savvy in getting their structures rigid enough on the road so they don't either crack from inadequate flexibility where it belongs or leak from too much flexibility in seam areas.
All In My Humble Mixed Background Opinion, of course.
As long as we continue buying the crap, manufacturers will continue selling it. Threads just like this prove the point succinctly. Designing a cabover that will not leak is very simple, but it also costs money, and apparently not all consumers are willing to a pay a premium for a fail safe design. The problem is not with the manufacturers. The problem is with us because we accept it, and we reinforce that acceptance every time we drive a poorly designed motorhome off the showroom floor.
Since we are all generally accepting of poor workmanship and construction, then it follows that the only solution to keeping the water out is to improve our preventative maintenance.
Government regulation is not going to solve the problem. The only way to solve the problem is with our wallets...either through continuous repetitive maintenance, or ideally, collectively excluding poorly designed RV's from our purchasing decisions.
You appear to be very dissatisfied with whatever kind of RV you have but you should not expect that same experience of others.
I actually do not agree that class c's are "crap" and we should all stop buying them. Like most things in life there are varying degrees of quality with big swings in price tags. Base your buying decision on what's important to you but please stop complaining about the******at the bottom end. If it's important to you then pay more and move up in quality. BTW: I'm a PHD
