JRscooby wrote:
warrenjo46 wrote:
Reisender wrote:
It would be nice if they would extend the regs to all the tuner pickup diesels out there. Stinky beasts. And loud. Ugh.
My thoughts exactly. If your vehicle has emission controls legal at the time of manufacture it should pass. If not you should be required to repair.
Should do roadside checks If wear or use is causing the issue, you have a limited time to use it and get it repaired. But if the test determines it has been modified, driver leaves in cuffs. Family is sent walking. Vehicle leaves as load. It is sold at auction to somebody that can repair.
Sounds about right.- JRscoobyExplorer II
Should do roadside checks If wear or use is causing the issue, you have a limited time to use it and get it repaired. But if the test determines it has been modified, driver leaves in cuffs. Family is sent walking. Vehicle leaves as load. It is sold at auction to somebody that can repair. - warrenjo46Explorer
My thoughts exactly. If your vehicle has emission controls legal at the time of manufacture it should pass. If not you should be required to repair. - It would be nice if they would extend the regs to all the tuner pickup diesels out there. Stinky beasts. And loud. Ugh.
- JRscoobyExplorer IINot a lawyer, but I know many states do restrict what vehicles from out of state, commercial or not, do in their state.
Some states let you tow a boat behind your 5th wheel RV. Some even allow boat behind a pull behind. Other states, you got to make 2 trips.
Courts have declared state laws that regulate trucks are not the same as regulating commerce. - valhalla360Navigator
Matt_Colie wrote:
Vahalla360,
You have obviously not watched as California has ignored numerous federal statures over the recent years. This is standard practice there and they work it up to the constitutional level.
Matt
It's different from the CARB rules of the past. Those are sketchy but apply to vehicles sold in California, so they mostly skirt the interstate rules.
The impact in the rest of the country is at least theoretically, not directly attributable to California. Some other states have simply adopted CARB rules and with a high enough percentage of vehicles sold, many requirements simply get adopted by manufacturers as standard...but it's not a hard mandate from California limiting interstate commerce.
Again, this is all sketchy but it at least has a veneer of not directly impacting interstate commerce.
This rule is different as it would apply directly to interstate commerce including vehicle, not sold, registered or driven by Californians... if they include the out of state vehicle testing.
PS: Federal control of interstate commerce isn't limited to commercial trucks. Pretty much any travel across the state line is interstate commerce. - Bruce_BrownModeratorSo what would they do with ours? Its an '08 MH with a '06 spec pre-emmission engine in it. No DEF, no DPF, heck we can even burn high sulphur diesel.
- agesilausExplorer III
jorbill2or wrote:
agesilaus wrote:
They would have to build and staff dozens of entry stations, how many roads cross the Cali border. I was watch one video earlier where the guy making it crossed the CA-NV border at Rhyolite.
And worst case even if your RV is in perfect condition they may hold you up for hours at the inspection station and charge you big bucks for the inspection. Have to pay all those Cali state salaries to man those stations. And this in the state where lifeguards can make $200K a year.
They already have port of entry stations on every road into calif ! There is a agricultural station stop already that’s staffed
Well the video showed the actual crossing, the fellow doing it got out (Hwy 190) and walked a couple of hundred feet across the boundary line and there wasn't a building in sight. I count 10 border crossings between Lake Havasu and the north end of DVNP. And I doubt that most of them have ag stations.
And there are maybe 15 more further north.
If they actually carry this out I suspect they will used the tried and true sticker system, like they use on tags. That way the cops can identify people without a current inspection sticker and not stop every RV on the road. agesilaus wrote:
Cali is going to start testing Class A's over 14K in 2024 visitors included:
RVTravel Mag
Good to see. Clean air is nice to breath.- jorbill2orExplorer II
38,782 PostsLatest Activity: Sep 10, 2026
