cbeierl
Apr 03, 2016Explorer
simionsen wrote:
I have a 2007 Itasca sunova 35J
house batteries charge when on shore power as well as when the generator runs, but not when driving.
In a small compartment to the right of my steps are the two items. On the left in this compartment I have a silver battery solenoid isolator. I changed it out for a new one. It still does not click and doesn't charge my house batteries. To the right of the isolator is the battery disconnect. It does seem to be working. It clicks on and off and does disconnect the house batteries. I would post a pic, but not sure how to. I have checked the fuse on the relay and it is not blown. I don't want to take it in if it's any easy fix that I don't know about. Thoughts please.
David
The Battery Mode Solenoid can be seen on page 2 of the Body, 12 Volt Wiring Diagram for your coach. It is controlled by the yellow wire labelled LR. When that wire supplies 12V to the solenoid it will close, connecting the two battery banks together.
The Wiring Identification Guide provides info about that wire:
LR / 14 YEL BATTERY MODE SWITCH (AUX START SWITCH) BATTERY MODE SOLENOID (AUX START SOLENOID)
The lower left corner of page 8 of the Automotive Wiring Diagram for your coach shows the wiring harness for the Battery Boost switch on the front panel. It has three yellow wires connected to it, labelled LR, LS, and KE. Here's the info from the wiring identification guide for the additional wires:
LS / 12 YEL OVERCURRENT PROTECTION 20A BREAKER TYPICAL,COACH FEED GENERAL PURPOSE(BATTERY MODE, RADIO POWER,BATTERY CONDITION
KE / 14 YEL RUN ONLY POWER SOURCE GENERAL PURPOSE(RELAY TRIGGER, REAR AUTO HTR,DRL,MONITOR,ETC
Normally the Battery Boost switch connects KE to LR, which means that the Battery Mode Solenoid should be closed whenever the engine is running and open when it's not. When the Battery Boost switch is pressed it will connect LS to LR, causing the Battery Boost Solenoid to be closed as long as the switch is held.
If you have a Ford Chassis, looking in the upper right corner (location D-1) of page 2 of the Automotive Wiring Diagram you can see that KE connects to the ACCESSORY FEED #2 RUN ONLY in the chassis-supplied wiring harness. If you have a Workhorse chassis, looking in the upper right corner (location D-3) of page 5 you can see that KE connects to pin C7 in the Workhorse I/P Convenience Center.
Since you indicated in a subsequent post that the Battery Boost switch doesn't seem to be working either that would indicate three possible problems:
- Defective Battery Mode Solenoid
- Bad wire LR between Battery Boost Switch and Battery Mode Solenoid
- Defective (or unplugged?) Battery Boost switch
If you have 12V at the terminal on the solenoid where LR is connected when the engine is running and when the Battery Boost switch is pressed then the problem is presumably the solenoid--replacing it should fix things up.
If you don't have power at the terminal then you'll need to make your way back towards the switch to figure out where things are going wrong.
38,780 PostsLatest Activity: Aug 05, 2026
