smitty2
Jan 27, 2013Explorer II
Hi Lou - when i first got the rig I was having trouble getting the cable input to work. I noticed how the receptacle on the outside seemed to be lined up with the lower panel on the cupboard on the inside. I removed the panel to start tracing wires and it was fruitless. No idea where they went/go from there and the cable on the inside was connected tight. Next logical step was to check the cable on the back of the tv to see if it was on tight. When I looked there I found the cable was attached to the antenna input, not the cable input. I switched it to the cable input and its been working fine since. Now I have to wonder, as I have a tv antenna up there as well, how to hook up the antenna. There wasn't a second cable coming in behind the tv to hook up. So how is it wired? Lemme know what you find!
38,780 PostsLatest Activity: Aug 05, 2026
