ksanford
Sep 05, 2021Explorer
kmiller wrote:
Has anyone on their generator modified a slide framed tray which slides out or modify the frame for there generator so its easier to work on ? Its such a big job to change oil!
If it is hard to change because you are removing the side cover, you don't have to do that. I found out after doing so. There is an access door on the bottom of the generator that makes it much easier. I also changed the fuel filter through that access door.
If you don't have a manual, it can be downloaded at www.cummins.com/rv-generator-manuals
That is how I figured it out.
Wayne
38,780 PostsLatest Activity: Aug 05, 2026
