kmiller
Mar 24, 2022Explorer
Need help with troubleshooting my battery problem. My battery will not charge and is hook to shore power. Yet I hooked a power cord directly to the battery charger and the battery charger works. I noticed the Xantrex Sine Wave inverter 1000 W indicator light will not light, Tried to reset it several times, no luck. I'm not sure if I need to replace the Inverter. I called for Xantrex technical support was a waste of time. I don't see a tag with the model number or the serial number. I assume it is a 1000 Inverter and help if you had this problem and info on unit ?
