TheoWarrior
Mar 24, 2022Explorer II
Lou R wrote:
When mine blew-up, the 110 outlets that use the inverter would not work.
My mechanic took the wires that lead into and out of the inverter and connected them together white to white black to black bypassing the inverter. Then all the outlets worked. You might try this approach. I never replaced this inverter, way to costly.
Lou, are you talking about the shore power/generator automatic switch that sits behind the microwave? (I replaced mine, 50 Amp Transfer Switch Pmts-50)
I may be wrong, but I think Kmiller is talking about the inverter box that converts 110v to charge the 12 volt system. it has a 110 volt plug that plugs into an outlet next to the entry door storage compartment.
