Old-Biscuit
Oct 04, 2013Explorer III
Didn't come with installation instructions?
The 'heating rod' goes in the water heater tank drain......then it should have a 't-stat' that goes against tank wall (to control the on/off of rod---temp control) and then you have to plug it into a 110V AC power source (outlet that you install)
You leave the propane heating system alone....use it as normal.
The electric rod is used as a supplemental heating source (when AC power is available)
If you have a Suburban Brand water heater you still need to use an anode rod.
Some of the aftermarket kits have a small anode rod that is part of heating rod.
FYI.....neither Suburban or Atwood recommend them.
Doesn't mean they can't be used.
38,769 PostsLatest Activity: Apr 04, 2026
