Since all of this started with a storm, I would guess a lightning strike which probably caused any damage. It is pretty hard to argue that after the transfer switch was replaced and everything now works fine, the problem was anything but the transfer switch. I don't know what in the pedestal could have been repaired, since there is no mechanical items other than breakers in them. My guess is since the electrician was there, they may have replaced some breakers since it is very cheap to do so, or they may have replaced the 20 amp GFCI outlet, since they fail on a regular basis, but failure of either a breaker or the 20 amp GFCI would not cause the problem you were having.
What causes voltage fluctuation is the loss of the Neutral. If your transfer switch had failed and was not connecting the Neutral when plugged into shore power, that would cause voltage spikes. So would the loss of the neutral in the pedestal, but the problem would have been solved when the pedestal was repaired, or would have continued after you replaced your transfer switch if they didn't repair it when they checked the pedestal. Again, the most likely explanation is a lightning strike that would have damaged your appliances and the transfer switch. That would be an "Act of God" and nobody's fault. Your insurance should cover the damages if that is the case.
BTW, since the transfer switch is past the surge protection system, the surge protector won't stop that voltage fluctuation.
