cpoo's avatar
cpoo
campgrounds with cable boxes
A new thing to me is the growing number of campgrounds that now use a cable box instead of the old analog where the box was not necessary. In the old days I connected the cable to the coach and all Tv's after a scan had cable channels. Now with the box I must run a coax through the window and hook up to main tv and only that tv has cable. Are there options I am missing? With satellite I am only trying to get local channels. I can use my antenna and get locals in many places so cable is not needed but some places are out of range and the only option for networks is the cable.
  • mdamerell wrote:
    Maybe a function of the TV, but the newer digital TV's should just need a coax cable to the RV's connection. The tuner in the TV should take over from there. An older analog TV will need a box.
    We have stayed at a couple of campgrounds with digital TV and all we had to do was hook the cable to the campers connection, ensure the amplifier was turned off and program the TV.
    Kind of defeats the purpose if you have to run a wire through the window.
    Interesting. I did that and got nothing. All my TV's are new digital. Campground said everyone needs a cable box. Very small box but has its own remote and without it the signal is not translated. The cable guy was in the campground tightening and fine tuning connections. He saw my setup and didn't mention that I would not need the box and I forgot to ask. I do what you do on old systems as well.
  • Welcome to the wonderful world of digital-only cable and pay TV.
  • Maybe a function of the TV, but the newer digital TV's should just need a coax cable to the RV's connection. The tuner in the TV should take over from there. An older analog TV will need a box.
