lordnorth's avatar
lordnorth
"Camping Brownout" or "New Converter/Switcher in my Future?"
Took our "new to us" 2011 Coachmen Mirada out for our first camping trip -- a one-nighter to the local state park.
Good news is that we made it back with absolutely no damage to vehicle or occupants. Always a plus, right?
I do believe that my converter is having issues. As this is my first coach, I'm just not really certain how these things work.
First off, I believe that at least one of my two deep cycle 12 volt batteries is defective. This may or not be the major cause of the problems, but wanted to get advice before just randomly replacing things...
While on 50-amp shore power the lights would gradually dim more and more until the radio would cut out and some warning alarm (CO?) would sound. A few moments later I would hear the converter fan turn on and the lights would come up full. The converter would run for a while then shut off and the cycle would repeat.
I *thought* that when on shore power that the converter would be "converting" full time. It would appear that mine is only converting when the batteries die, then switching back off again.
Is this a battery problem, a converter problem, a switcher problem, or other?
Thanks!
  • What I think the others are saying if you have a bad battery, it could be making the converter work over time till it over heats, and turns off. The good battery runs down the converter cools down starts working again and the cycle starts all over again.
    Pull the bad battery and see if it starts working right .
  • Need to remove and separate the batteries for testing.
    RV should operate fine with no battery if the converter is working.
  • If you replace the battery, replace both or the old one draws down the new.
  • Chris, you need to Google 12volt side of life, read, it's a great read. JMO
