dougrainer
Nov 28, 2022Nomad
Cut out the top of the shroud just enough to lift cover around the washer/screw. RVP makes a replacement metal fan cover that has BOTH rear nut inserts. But you can make and install your own bolt and screw kit. Once you remove you will see how to do it. You use an oversize metal plate or washer to cover the hole you cut in the shroud. If up front where the evap cover is, same procedure but it is easier to make a new nut insert kit. Doug
38,721 PostsLatest Activity: May 22, 2025
