Dutch_12078
Aug 30, 2014Explorer III
His A/C alone does not draw 30 amps, but more like 12 or 13 while running, with a higher momentary starting load. As long as the voltage is adequate, it'll run fine on a 20 amp circuit, although the amount and type of other items that can be used at the same time will be limited. The A/C would have to be shut off to use a microwave for example, but it is doable and done by many RV'ers, most commonly when plugged in at home.
38,777 PostsLatest Activity: May 24, 2026
