blueswon wrote:
I have 30 amp service travel trailer. In the summer I have problems with the breakers tripping when I run ac and other things. Someone told me I can buy a plug converter (to plug in the 30amp TO 50Amp plug)to 50 amp service at the camp ground. Is that safe?
It's still going to trip the main in the RV breaker panel and that's a good thing. Also keeps you inside in most cases and not out in the weather for resetting.
Do you have two A/C's and if so, you may be able to install what's called a dual power adapter, so that you can run the rear air separately from another pedestal circuit and this should alleviate about 13-15amps from the total load.
