TubaPete
Aug 30, 2014Explorer
As said, the actual voltage supplied is more important than the labeled number of amps. 20 amps, 30 amps, etc. in this case are more indicators of system design than what you might actually get. If the AC runs without tripping any breakers and you have at least 108 volts you will likely be OK>
